43 Users Online (41 Members):
Forums >> Revit Building >> Technical Support >> Re-referencing Elevation Tags - Revit Architecture 2008
I need to relocate the elevation tag from one view to another. I don't care if they show up in both, I just want to relocate the elevation marker from one plan to the same place on another view of the same plan. I know that going to View and selecting Elevation will create another elevation all together. I do not want to reference another elevation as it will appear as "SIM"... so any suggestions? All expertise is greatly appreciated!
Your elevations should show up unless they have been turned off. Check the Visibility/Graphics and make sure they are not hidden in the view.
Thanks. I'm actually gong to answer my own question: REMEMBER TO DOUBLE CHECK THAT ANOTHER TEAM MEMBER HASN'T PLACED ANOTHER ELEVATION TAG DIRECTLY OVER THE ONE THAT ALREADY EXISTED. Unfortunately, I had given up and re-created the elevation by the time I'd found the duplicate. It's all a learning process, er something.
REVIT 2008 Changing tags!!! |
Mon, Aug 27, 2007 at 12:25:02 PM
Changing elevation tags to Shared Coordinates |
Thu, Aug 20, 2009 at 8:59:54 AM
elevation tags |
Tue, Jul 1, 2008 at 2:27:02 PM
Exporting a walkthrough path from Revit Architecture 2008 to Autodesk Viz 2008 |
Tue, Nov 20, 2007 at 12:37:43 PM
Getting started |
Sat, Mar 22, 2008 at 2:47:59 AM
Members: | 2056530 | Objects: | 23074 | Forum Posts: | 152325 | Job Listings: | 3 |
