Forums >> Revit Building >> Technical Support >> Cut plane in family
5 Posts No Rating |
I created a generic model of a walk in freezer for a grocery store that I am designing, but it is not showing properly when I import it into my model. I have the top offset of my floor plan view range at 7'-6", the cut plane at 4'-0", and the bottom at 0'-0". The roof of the freezer is at 10'-0" so the freezer should be displayed cut, but it is showing the roof. Everything appears correct in the 3D views. I have tried to use a plan region and changed the view range properties, but nothing seems to work. Any help? I am using Revit Building 9.1
Post the family.
5 Posts No Rating |
Attached is the freezer family
Ok, the reason for this is that is that familes dont really have a different view for being cut. You can put in a cut pattern and all, but really it will show up the same. If you have a box and you look at the top you see just a solid 4 sides, you would think that cutting through the box you would see the 4 walls, but this isnt so with familes. What you sould do here is create that as a group, that or create it as a seperate file and then link it into your file where you want to place them. Familes are more intened for things like a table, I can see how you wanted this to be a family, but with all the things you ahve in it, I think its a bit much. Groups may give you some issues, but if you stick with how you have your family built you should be fine. HTH Grant Doherty
5 Posts No Rating |
Thanks for the help. I linked the family and it appeared like I wanted. My Buffalo Bills are going to be seeing your Broncos opening week this year. Good luck. Thanks again! Lets Go Buffalo!!
Your Buffalo Bills have two of my buddies from college that they picked up this year. I dont know who to chear for now.
How to control where the cut plane is for families? |
Sun, Nov 22, 2009 at 10:20:00 AM
Generic model cut plane & plan regions |
Thu, May 20, 2010 at 6:44:23 AM
Cut plane problems with Families - Revit 2013 |
Tue, May 21, 2013 at 2:29:28 PM
Cut framing with ref.plane in families? |
Thu, Apr 8, 2010 at 7:18:07 AM
window above cut plane is visible. why? |
Fri, Nov 27, 2009 at 9:25:11 AM
Members: | 2101351 | Objects: | 23173 | Forum Posts: | 152294 | Job Listings: | 3 |
