98 Users Online (97 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Window with angled sill
Fri, Aug 10, 2007 at 4:59:18 PM | Window with angled sill
iREV
3.5 Stars: 3 Votes
I am trying to create a window family that has an angled window sill.  I am having problems with the opening cut just being a strait void form extrusion.  Does anybody have any suggestions on how I can get a window family with and angled sill that will only cut part of the wall that the sill is angled on?
Sat, Aug 11, 2007 at 10:44:08 AM | Window with angled sill
TomDorner
4.5 Stars: 25 Votes
You can use a void in the window family to cut the wall rather than the 'opening'.  Be aware though that you cannot mix the voids/openings in the window family so you have to use one or the other.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Fri, Nov 16, 2012 at 9:48:54 AM | Window with angled sill
romanosyr
any way to do this without using voids?  I have multiple walls that i need the window to cut through, this can only be done with opening not voids.
Fri, Nov 16, 2012 at 9:52:27 AM | Window with angled sill
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Add the sill right to the window family
Fri, Nov 16, 2012 at 10:40:26 AM | Window with angled sill
romanosyr
the problem is that the sill is sloped rowlock and when its added to the family and placed at the correct height there is a piece of wall that shows through the sill, easy fix if using voids but when you need to use openings there doesnt seem to be a way to fix it.
Fri, Nov 16, 2012 at 10:47:52 AM | Window with angled sill
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Can you attach a photo of your problem.  I am having a hard time picturing it.
Fri, Nov 16, 2012 at 10:49:58 AM | Window with angled sill
romanosyr
are you saying create the sweep/void in another family then load that into the window family?
brick sill below window on brick wall
Thu, Mar 13, 2008 at 6:10:24 PM
Angled Window (angled jambs on both sides)
Wed, Apr 13, 2011 at 9:48:15 PM
Creating multiple window openeings that have a sloped sill
Thu, Nov 13, 2008 at 7:34:18 AM
window sills
Sun, Jun 18, 2006 at 5:16:18 PM
Sloped interior window sill in wall
Tue, Feb 14, 2012 at 3:30:27 PM
Page generation time: 1.1846
