108 Users Online (106 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Adjusting the hatch pattern inside of a filled region?
Fri, Aug 10, 2007 at 10:09:31 AM | Adjusting the hatch pattern inside of a filled region?
synklare
If I create a filled region, is there anyway to move the hatch in the region so that it lines up properly?
Fri, Aug 10, 2007 at 10:38:09 AM | Adjusting the hatch pattern inside of a filled region?
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
If your filled region is using a "Model" type hatch pattern you can use Align, Move, Rotate commands to adjust the pattern.
If it is a "Drafting" type pattern you cannot adjust the lines.
Wed, Dec 3, 2008 at 4:22:04 PM | Adjusting the hatch pattern inside of a filled region?
dfitzladdy
5 Stars: 3 Votes
Okay, so how do you get a "model" filled region?
Wed, Dec 3, 2008 at 4:58:09 PM | Adjusting the hatch pattern inside of a filled region?
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
When you are setting up the properties of the filled region you will be selecting a hatch pattern. In the pattern dialog there are two radio buttons. One says "Drafting" and the other says "Model". Select the Model type.
Thu, Dec 4, 2008 at 8:05:53 AM | Adjusting the hatch pattern inside of a filled region?
dfitzladdy
5 Stars: 3 Votes
that seems so easy, however the MODEL option is grayed out.  I'm only allowed to select DRAFTING.
Thu, Dec 4, 2008 at 8:19:09 AM | Adjusting the hatch pattern inside of a filled region?
dfitzladdy
5 Stars: 3 Votes
hmm.... so i used a different hatch pattern to do EDIT/NEW>DUPLICATE and was able to select model.  not exactly sure how that happened........
Fri, Dec 5, 2008 at 11:07:40 PM | Adjusting the hatch pattern inside of a filled region?
hugh
3.5 Stars: 4 Votes
If you open both pattern files with a text editor, you'll see that on contained a line containing TYPE=MODEL. The default is DRAFTING.
Find and open the file Revit.pat and read its leading comments for an explanation of what is occurring.
Hugh Adamson
www.hatchkit.com.au
filled region pattern color changes when drawing scale changes
Thu, Apr 14, 2016 at 7:32:06 AM
hatch pattern in material anomolies
Fri, Aug 26, 2016 at 9:35:26 AM
change linetype of a hatch pattern
Mon, Oct 5, 2020 at 7:58:40 AM
Blank filled Region
Fri, May 2, 2008 at 12:30:12 AM
HATCH IN FILLED REGION WONT SHOW
Wed, Oct 1, 2008 at 8:59:51 PM
Page generation time: 1.2106
