123 Users Online (122 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Room Settings
Fri, Aug 10, 2007 at 7:33:32 AM | Room Settings
JPotts
Using MEP,
Does anyone know a good way to create a room in a space that is not fully boxed in by walls? see attached pdf
Fri, Aug 10, 2007 at 8:34:38 AM | Room Settings
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
You can use "Room Separation". Draw the room separation lines across any space that is not room bounding.You can turn the lines off in VG if you don't want to see them. The room bounding line tool is found on the Room and Areas tab in 9.1. Not sure about RA2008
room tags in enlarged plans
Wed, Jan 14, 2009 at 12:37:18 PM
Room tags not visible
Sun, Mar 8, 2015 at 9:07:24 PM
Room Tag is lost visibility is on
Tue, Nov 20, 2012 at 7:04:09 AM
Any way to change the default settings for placing ceiling grid?
Tue, Apr 3, 2007 at 11:46:04 AM
Room Boundaries
Tue, Oct 29, 2013 at 1:23:19 PM
Page generation time: 8.9266
