68 Users Online (67 Members):
Forums >> Revit Building >> Technical Support >> Imported Details from AutoCAD coming into Revit Black Out!?
![DLicata Avatar](user_avatar/31618.jpg)
![3.5 Stars: 7 Votes](/images/stars_3.5.gif) |
Like the title says, I'm importing some text that goes along with some details from AutoCAD to Revit Architecture 2008 and instead of showing the insulation and other detail components its coming in all blacked out... any ideas? Can I import this onto a detail view or into a legend? This is really annoying all the text comes in perfect. Thanks for any help.
LHAA Licata Hansen Associates Architecture Reno, NV USA |
Anybody know a better way to get details into Revit from AutoCAD?
![psymon Avatar](user_avatar/9799.jpg)
![3.5 Stars: 6 Votes](/images/stars_3.5.gif) |
It may be an issue of linetype thickness? The best way to do this, if they are standard details to be used agin is to make a new detail family, import the autocad detail then load that into your project. There is a file accesable under the file menu - import/export settings/import line weights-dwg This file maps the Autocad colours to Revit Line weights, you should customise this to your office standards. This will apply to autocad drawings directly imported into your project or into families.
Ok I'll see what I can do. Thanks, for now I just redrafted the details and what not in Revit so it wasn't that bad. =)
Autocad details with hatch showing as black/solid |
Wed, May 22, 2013 at 11:47:29 AM
Rendering is coming out black |
Fri, Aug 1, 2014 at 9:06:25 AM
LInked AutoCAD details into Revit 2009 workset project |
Tue, Jun 28, 2011 at 5:07:32 PM
Black background on text (imported DWG) |
Thu, Feb 18, 2016 at 8:38:47 AM
Importing .dwg details |
Wed, Jul 12, 2006 at 12:23:47 PM
Members: | 2016974 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
