137 Users Online (135 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> I want to know how can I calculate the total cost with revit???
Thu, Jan 27, 2005 at 3:57:04 AM | I want to know how can I calculate the total cost with revit???
emad
I want to know how can I calculate the total cost with revit??? and also there is big trouble in revit that in the type parametres there is the cost parameter in the walls paramteres and I couldnt apply any formula in this paramtere because I want to calculate the cost by (cost=lengthx500$)for example ??? and so on for the other elemnts???
Thu, Jan 27, 2005 at 5:26:04 PM | RE: I want to know how can I calculate the total cost with revit???
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Don't use this cost parameter. In the wall schedule choose calculated value and name it cost per metre (add your own regional setting) Then select the type to be a number. Now we need to add a formula: (Length/1000)*500 This will effectively calculate the cost per metre for each stretch of wall. Now in sorting and grouping tick grand totals. Title, count and totals. Then in formatting select your newly created parameter and then tick calculate totals. THat should do it. HTH.
Thu, Jan 27, 2005 at 8:20:42 PM | RE: I want to know how can I calculate the total cost with revit???
ale02
ale02 Avatar
3 Stars: 3 Votes
I prefer to create another parameter for unit rate (in this case the 500$) in the formula so that I can incorporate different rate for different type of wall. the formula in this case would be (Length / 1000) * unit rate
Life is never easy but nor it should be complex. Just stay simple Smile
Fri, Oct 31, 2008 at 11:39:48 AM | I want to know how can I calculate the total cost with revit???
consistence
For materials, I use the material's cost parameter with the families area parameter.  Just remember how the cost relates to area i.e. cost per sf or square yard.
Process
  1. Add the Material: Area field and Material: Cost field to your schedule.
  2. Make a Calculated field called total cost as a currency field.
  3. Enter the formula:  Material: Area/ 1 SF * Material: Cost
  4. The key here is to cancel out the area unit so you get a consistent currency unit.
  5. Also remember that there is a space after the colon.
This applies to any assembly cost or unit cost as well.  Cancel out the units.
Sun, Apr 4, 2010 at 9:20:45 AM | I want to know how can I calculate the total cost with revit???
onie012
Process
 i tried this but since i'm using metric i placed m² but it said inconsistent units how do i cancel the square meter already tried SQM still didn't work
Sun, Aug 28, 2011 at 12:30:42 PM | I want to know how can I calculate the total cost with revit???
Robin4rhca
for metric, use 1 m2 not 1 SF  ...note the space between 1 and m2. otherwise it throws an error
Sun, Mar 31, 2013 at 12:02:27 PM | I want to know how can I calculate the total cost with revit???
ambrozote
5 Stars: 2 Votes
Hello,
This thread was really helpful as I was having a inconsistent units error.
Still, The calculated value column turns empty after I type the Material:cost anything different than 0.
Why could this be happening?
many thanks
Revit Architecture 2013
ArchiCAD 16 Win
Windows 7 Enterprise 64-bit
total cost
Mon, Jan 17, 2005 at 5:35:01 AM
Calculating two Formulas on the same row in a Schedule
Thu, Dec 16, 2010 at 10:04:48 AM
Area Schedule Estimated Cost
Fri, Aug 21, 2009 at 10:09:36 AM
Total Cost Estimate (detailed)
Fri, Sep 12, 2008 at 12:13:13 PM
Material cost per sq ft formula
Mon, Sep 21, 2009 at 9:06:25 AM
Page generation time: 2.4009
