58 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> EXPORT to autocad TEXT PROBLEM
Wed, Aug 8, 2007 at 5:43:28 AM | EXPORT to autocad TEXT PROBLEM
bjwson
2.5 Stars: 3 Votes
Question / problem can you pls. look into it and help.
i have a Room tag (attached) and the font i used is Romans and when i export it to Autocad it comes as Romans but the text itself has some kind of thickness and i have to explode it which i dont want to. Can you look into it as to why it's like that.
Thanks in Advace.
bjwson
Wed, Aug 8, 2007 at 7:28:39 PM | EXPORT to autocad TEXT PROBLEM
psymon
psymon Avatar
3.5 Stars: 6 Votes
The reason is that Autocad will map the Revit fonts as True Type Fonts. This is actually specified in the code of the text itself. If you look try to edit the text you will see that there is a font override of RomanS true type font.
Only SHX fonts in Autocad do not have a thickness. You cannot make Revit automatically map to shx fonts as far as I know, you would have to change them in the Autocad Drawing. DO NOT explode the text, just change it's properties. You should be able to select all the text and us the properties dialogue box to change it all at once.
Thu, Aug 9, 2007 at 12:26:16 AM | EXPORT to autocad TEXT PROBLEM
bjwson
2.5 Stars: 3 Votes
Thank You for the Reply.
Here I have another question..i understood that we can change the style name via properties box but i want to change the formatting it is having ie. text is coming with some thickness.........there is an answer too to this problem is that you select text go to text editor select the text and click additional options button (Autocad200Shadey and remove formatting and remove all formatting.........it does the job but i want to do all at a time.........instead of selecting each text and doing it.
pls. see if there is any way this can be done.
Thanks,
BJW
Thu, Aug 9, 2007 at 12:42:07 AM | EXPORT to autocad TEXT PROBLEM
psymon
psymon Avatar
3.5 Stars: 6 Votes
I am not sure if it will work, but can you freeze all the layers except for the one with the text on it, then select all the text, then change the properties?
You will have to try various ways of doing this.
sorry, HTH
Thu, Aug 9, 2007 at 12:44:59 AM | EXPORT to autocad TEXT PROBLEM
bjwson
2.5 Stars: 3 Votes
thank you..........if i get any solution to this problem i will post it.
BJW
Revit Export to AutoCad text issue
Thu, Dec 16, 2010 at 1:38:19 PM
Column Grid Text Exported into AutoCAD as Annotative Text
Wed, Jul 24, 2013 at 9:14:29 AM
Text Problem when exporting to CAD
Mon, Feb 9, 2009 at 12:50:23 PM
Export to DWG - Text Scaling
Mon, Feb 4, 2008 at 4:01:11 PM
Solid Body Text for File Export
Wed, Sep 14, 2016 at 9:34:33 AM
Page generation time: 0.9255
