115 Users Online (115 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Sloped Column???
Tue, Aug 7, 2007 at 12:47:03 PM | Sloped Column???
pgalla
Does anyone out there know how to create a sloped column in Revit Structure 2008? Base at 0,0,0 and top at 0',2',40'
Tue, Aug 7, 2007 at 2:15:11 PM | Sloped Column???
justinblack
Still this is impossible.  We had to use a Beam that was sloped.
Tue, Aug 7, 2007 at 8:03:27 PM | Sloped Column???
sdbrown
5 Stars: 3 Votes
No, its not impossible at all.  Just create your column with a blend instead of a straight extrustion, have 2 sets of ref. planes on controloing the location at the top, one at the bottom.
Wed, Aug 8, 2007 at 6:20:33 AM | Sloped Column???
pgalla
Here is is the basic of what I'm trying to do. The end result will look like a fan effect.
Wed, Aug 8, 2007 at 6:34:56 AM | Sloped Column???
pgalla
You must bhe able to see column in level 1 and 2
Fri, Nov 14, 2008 at 2:06:37 PM | Sloped Column???
cketros
I create this slope wf column and test a little seem ok for now (I think), but right now only one orientation and can only slope left or right. may be someone can help define this thing to have it slope and rotate to any angle and orientation. Again this file for drafting purpose don't know it will past the analytical model.
sloped column with analytical line
Mon, Dec 8, 2008 at 8:39:23 AM
Need Help on Sloped Beam-Column Connection
Fri, Apr 29, 2016 at 1:50:43 PM
Tapered or sloped wall or colum.
Wed, Nov 30, 2005 at 12:41:31 AM
Cut a sloped beam
Fri, May 11, 2012 at 3:48:19 AM
DISPLAY COLUMN LABELS
Wed, Sep 8, 2010 at 3:53:41 AM
Page generation time: 0.6186
