61 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Custom Ceiling Grid
Tue, Aug 7, 2007 at 12:12:46 PM | Custom Ceiling Grid
Silva
Fistly, I can't seem to find where the default ceiling families are stored - they're are a couple default families stored in my project but i'd like imperial versions of them loaded.  Where are they located? And, how do I go about creating a custom acoustic tile ceiling grid pattern - i need a pattern that has 1-1' tile sandwiched between 2-2' tiles?  I can't seem to edit the Compound Ceiling: 600mm x 1200mm grid.  I've tried using the ceiling template tool with no luck.
Thanks!
Silva the newbie.
Tue, Aug 7, 2007 at 2:41:37 PM | Custom Ceiling Grid
architerporange
I'm sure there is a better way, but...
I would make multiple ceilings for each tile size.  So, make several ceilings in the same room.  It should work out fine.
Light fittings in ceiling grid
Tue, Feb 8, 2005 at 6:33:49 PM
Ceiling Grid
Wed, Mar 16, 2011 at 3:15:50 PM
Ceiling Grids in Revit 2011
Fri, Jul 22, 2011 at 8:35:24 AM
rendering ceiling grid
Wed, May 16, 2007 at 1:37:31 PM
Can we create our own ceiling grid?
Mon, Jul 11, 2011 at 8:35:01 AM
Page generation time: 0.6349
