80 Users Online (79 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Titleblock elements on or off
Mon, Aug 6, 2007 at 4:45:43 PM | Titleblock elements on or off
stanmpd
stanmpd Avatar
4 Stars: 4 Votes
In our titleblock there is a stamp that has 4 variations based on the drawing type and stage, I.E. preliminary, ready to be signed etc.  I currently have the stamps imported as CAD items with the different stamps being on different layers so they can be turned on or off in the imported family tab of the View Settings.  Being that I would like to have a Revit only titleblock, is there a better way to have these stamps come in with our title block and turn them on or off to get the correct stamp or no stamp at all as needed without bringing them in as separate families  and dragging them in on the drawing sheet or turning import family layers on and off?
Thank you
stanmpd
Belz A&C
Memphis, TN
Mon, Aug 6, 2007 at 9:59:09 PM | Titleblock elements on or off
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Of course!
Create your stamp as a generic annotation symbol.  Setup a parameter for the text value and also a parameter for visibility.
Then load it into your titleblock and link through the parameters into the titleblock family so they can be controlled in a project.
Let me know if you need more guidance.
HTH.
Regards,
Chris.
Tue, Aug 7, 2007 at 11:20:41 AM | Titleblock elements on or off
stanmpd
stanmpd Avatar
4 Stars: 4 Votes
I'll give it a shot.
Thank you
stanmpd
Belz A&C
Memphis, TN
Tue, Jun 24, 2008 at 4:09:15 PM | Titleblock elements on or off
bmpatel
I'm trying to do a similar thing with drawing issuances.  I would like to have certain text to be able to turned on for some sheets and off for others.  How would I go about doing this?  Would i need to make a generic annotaion family with just text?
Wed, Sep 3, 2008 at 8:52:10 AM | Titleblock elements on or off
tmd7766
tmd7766 Avatar
Here's what I did to create drawing issuances and other title block information:
Create a shared project parameter: Settings - Project Parameters - add - shared parameter - select - edit - if you dont already have a shared parameter file, create one and save it in a network location - New parameter - name the parameter and select the type: text for issuance or yes/no for an image.  Then select ok until you get back to the parameter properties box.  select the catigory: drawing sheet to be able to edit the text on each drawing sheet or project information for the text to update on all sheets - select a group parameter and select ok.  Go to the title block family.  create a label, edit the label. under the edit label box select add parameter - click select - select the parameter you just made, then move that parameter into the label.  Repeat for each issuance or electronic stamp or consultant's info.
Titleblock resized after export
Fri, Feb 7, 2014 at 8:40:40 AM
Getting Titleblock in centre of page
Tue, Mar 30, 2010 at 7:13:06 AM
Titleblock question
Thu, Jul 2, 2009 at 4:23:15 PM
Revit 2012 Export To DWG. Titleblock exported as Block.
Wed, Jun 12, 2013 at 6:16:24 PM
Titleblock Parameters
Tue, Apr 19, 2005 at 11:55:07 AM
Page generation time: 0.4707
