140 Users Online (139 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Imported DWG visibility?
Mon, Aug 6, 2007 at 4:03:47 PM | Imported DWG visibility?
rs3o
Total noob here, doing my first project which is a renovation.
I imported a DWG floorplan of an existing building and have been building my model on top of it. I would like to be able to mask off portions of the old floorplan so that they do not appear below newly renovated areas.  I figured the floor of the model would "mask" portions of the imported DWG for me, but the floor always seems to be transparent.  Is there any way to make the floor opaque?   Is there a better way to do this?  TIA.
Mon, Aug 6, 2007 at 4:06:16 PM | Imported DWG visibility?
rs3o
BTW, I'm using Revit Architecture 2008.
Mon, Aug 6, 2007 at 4:09:46 PM | Imported DWG visibility?
sdbrown
5 Stars: 3 Votes
All revit geometry will hide the dwg if the dwg is linked in and on the level. if its above the level you won't see it. If you imported it current view only, then it has draw order and you can click on the dwg and in the options bar chose background.
Mon, Aug 6, 2007 at 4:17:37 PM | Imported DWG visibility?
inverted
if you're just wanting to view it as solid while you're working, click on the icon at the bottom of the screen called "model graphics view: wireframe" and change it to "hidden line". or under view > hidden line. other than that, it might be that the material for the floor is set to transparent. check the view's properties > visibilities and graphic overrides and check out all of the settings for foors.
Tue, Aug 7, 2007 at 10:07:43 AM | Imported DWG visibility?
rs3o
Got it.  I had loaded my DWG the wrong way.  Reloaded it and everything was fine.  Thanks for the help!
imported DWG visibility
Fri, Apr 13, 2007 at 12:26:23 AM
Annotations accidentally snapped into linked dwg (Imported categories)
Tue, Jul 9, 2013 at 5:53:12 AM
Imported .dwg File Visibility Settings
Mon, Mar 14, 2011 at 5:29:07 PM
Imported dwg files
Wed, May 10, 2017 at 10:25:30 PM
imported dwg lineweights, linetypes
Fri, Aug 10, 2007 at 9:22:54 AM
Page generation time: 0.4391
