140 Users Online (139 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> "TO ROOM / FROM ROOM" DOOR SCHEDULE DISCREPANCY
Mon, Aug 6, 2007 at 3:26:22 PM | "TO ROOM / FROM ROOM" DOOR SCHEDULE DISCREPANCY
inverted
I have a curtain wall with 3 doors in it. The 2 outside ones are the same exact type, and the center one is a slider. The one on the right CORRECTLY shows the "to room / from room" of "lobby / vestibule". The other 2 doors show it INCORRECTLY. How can this be? I've checked to see if there are room-separation lines that might be messing with this, and I can't find any. Please See JPG I've attached. Please help!
Mon, Aug 6, 2007 at 10:25:51 PM | "TO ROOM / FROM ROOM" DOOR SCHEDULE DISCREPANCY
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
To/from room information is sketchy at best when it comes to curtain walls.  I always have issues with it either not reporting the room at all or reporting a room that isn't even anywhere near.
 I can't tell from your screenshot where those rooms are actually located?  But if you want this issue fixed post it as a support request.  I've already had a similar issue which i've posted as a bug and it is scheduled to be fixed in a subsequent release... Hopefully.
Regards,
Chris.
Tue, Aug 7, 2007 at 11:21:55 AM | "TO ROOM / FROM ROOM" DOOR SCHEDULE DISCREPANCY
inverted
Thanks for the reply. Yeah, I'm unfortunately noticing that most of my issues with Revit these days are legitimate bugs that i'm reporting with no good work-arounds. I think there are several things they can fix with the curtain wall tool.
Wed, Nov 9, 2011 at 4:00:51 PM | "TO ROOM / FROM ROOM" DOOR SCHEDULE DISCREPANCY
crwinchester
crwinchester Avatar
4 Stars: 5 Votes
Including be able to miter curtain wall mullions! Release 2012 and still no fix!
Wed, Nov 9, 2011 at 5:35:20 PM | "TO ROOM / FROM ROOM" DOOR SCHEDULE DISCREPANCY
Remember crwinchester, this site is not affiliated with AutoDESK.  You should register all complaints / suggestion with them.  AUGI maintains a wishlist.
"Room From" and "Room To" NOT updating in Door Schedule???
Wed, Jan 20, 2016 at 1:17:43 PM
Door schedule parameters not displaying "room names" from linked revit model.
Fri, May 15, 2015 at 1:22:11 PM
Schedules. How do I avoid having a schedule row for every door, room & window?
Wed, Aug 15, 2012 at 7:24:44 AM
automating door schedule ( From room # To Room #)
Thu, Jun 20, 2019 at 2:14:07 PM
Room Schedules In Revit
Sun, Dec 16, 2007 at 10:01:21 PM
Page generation time: 3.2548
