50 Users Online (47 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit 9.1 massing not printing correctly
Mon, Aug 6, 2007 at 6:57:53 AM | Revit 9.1 massing not printing correctly
bengine
Hi, I'm using Revit 9.1 and i've got some massing that won't print properly. There are several massing instances in the veiw, some grouped, some not, and there are certain elements that print as if the view is on wireframe but it's on hidden line. I've tried changing the material and checked the visibility settings - nothing has worked.
 Anyone had a similar problem or got any ideas?
Ben
Thu, Oct 4, 2007 at 11:12:48 AM | Revit 9.1 massing not printing correctly
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
I had the same problem.  Revit 9.1 for some reason likes to turn off the massing category randomly even if you turned it on last time you were in that view.  Just type 'VV' and make sure it has a check mark next to it and all subcategories that should work.
Denver, CO
Revit Architecture
Massing Printing Problem-solve (sort of)-Revit Architecture (2008)
Fri, Aug 24, 2007 at 3:15:21 PM
Massing printing problems
Tue, Feb 9, 2010 at 8:11:11 AM
Materials not printing correctly?!?
Tue, Oct 9, 2007 at 9:48:08 AM
Mass Object Not Printing Correctly
Thu, Feb 28, 2008 at 2:19:57 PM
massing problem in printing
Sun, Feb 14, 2010 at 7:36:22 AM
Page generation time: 3.2820
