31 Users Online (29 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Large dots at corner
Fri, Aug 3, 2007 at 11:38:53 AM | Large dots at corner
johnnyutah54
I need help!  I increased the lineweight of my walls in visibility graphics so I could quickly export some jpgs for a presentation...but in doing so it caused big fat dots to occur at all of the corners! What's wrong? How do I change it? Is there a different way I needed to do what I was trying to do?  I attached an image of what it looks like.  Thanks for you help!
Fri, Aug 3, 2007 at 1:21:56 PM | Large dots at corner
kesflower
3.5 Stars: 11 Votes
Instead of using an override in the Visibility/Graphics, go to Settings - Object Styles, and change your Wall lineweight there.  I have no idea why the visibility/graphics override is giving you the dots, but I do know that changing your cut lines in the Object styles will work to give you a consistent lineweight.
Edited on: Fri, Aug 3, 2007 at 1:22:29 PM
Ruth Rau
Main Street Architecture, P.C.
Mon, Aug 6, 2007 at 8:45:18 AM | Large dots at corner
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
The dots are depicting the "Projection Lines". In other words you are seeing the vertical edge created by the corner of the walls. Make sure you are adjusting "Cut Lineweight" for plan view and "Projection lineweight" for elevations. This should give you the result you are looking for. If you need to change the lineweights for all views then use the method of changing the object styles.
blue dots in linework
Wed, Aug 18, 2010 at 4:13:10 AM
Corner guards to snap to corner of wall
Tue, May 13, 2014 at 12:18:45 PM
Gray Dots on My RPC people
Sun, Oct 30, 2005 at 3:26:57 PM
Adding Dots to the Door Schedule
Fri, Dec 2, 2011 at 5:41:21 PM
Rendering problem (dots)
Thu, Dec 31, 2009 at 12:00:29 PM
Page generation time: 0.2741
