151 Users Online (150 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Element constraints - Revit Structure 2008
Fri, Aug 3, 2007 at 3:08:59 AM | Element constraints - Revit Structure 2008
phildixon
1 Stars: 1 Votes
Hi,
I've searched the forum but couldn't find the answer.
I have a column that is constrained to Level 1. How can I edit this so that the cplumn is not constrained to a level? In the element properties, I can't seem to change this. The 'Base Level' and 'Top Level' options only have the model levels in. I know I could delete the column and add another one but I wanted to find out if I could edit it instead.
Thanks,
Phil.
Mon, Aug 6, 2007 at 2:48:36 PM | Element constraints - Revit Structure 2008
TJKENNEDY
3 Stars: 2 Votes
I dont think you can set a column to unlimited like you can with a wall. Why do you want an unconstrained column?
Tue, Aug 7, 2007 at 2:32:58 AM | Element constraints - Revit Structure 2008
phildixon
1 Stars: 1 Votes
I'm not sure I do yet. I've just started using Revit having come from 3D+ so I'm still getting to grips with it at the moment. Someone mentioned to me that when you highlight the column, there is a 'disassociate box' that appears but I don't get this.
Tue, Aug 7, 2007 at 9:46:00 AM | Element constraints - Revit Structure 2008
TJKENNEDY
3 Stars: 2 Votes
I am not sure about disassociate, but there is detach in the options bar. If you attach the top of a column to a beam, it will move with the beam. Detach will make the column use the offset you give it in its properties.
Constraints Are Not Satisfied when opening file - Revit Architecture 2008
Wed, Aug 27, 2008 at 9:46:31 AM
Structure Suite 2008
Tue, Apr 17, 2007 at 3:19:53 PM
Revit 2008 - "Element is too small on screen" ?
Tue, Jul 24, 2007 at 1:55:42 PM
Project Browser - Revit Structure 2008
Tue, Jan 22, 2008 at 9:19:04 AM
Modyfing columns in Revit Structure
Thu, Nov 1, 2007 at 12:55:54 PM
Page generation time: 7.0143
