110 Users Online (109 Members):
Forums >> Revit Building >> Technical Support >> Column grid lines disapear in one section view.
Hi, I am using Revit 2008: I am working on a wall section and i cannot get the column grid lines to display. The visibility graphics are all checked on, I "revealed hidden elements" and the grid lines do not even show up then. It is like they do not even exist in this view; and it is only in this perticular section view that they do not show up, the col. grids are fine everywhere else. This has baffeled everyone in my office, can anyone help?
Is your section 100% perpendicluar to the grids? Are the grids on a seperate workset you dont have open? Does the view depth of the section cut through the grids?
Wow, my section cut was off by 0.2 degrees. Thanks for the help, i would have never figured that out.
.2 Degrees will get you every time. Some times I hate how precise Revit is.
column grid visibility |
Wed, Nov 15, 2006 at 3:43:13 PM
Column to Grid |
Tue, Sep 8, 2009 at 4:09:31 PM
Column Grid Visibility |
Fri, Jun 29, 2007 at 8:55:55 AM
Section cut_ wall sweep causes materials to disapear |
Tue, Feb 2, 2016 at 12:44:28 PM
Column grid text too wide to fit in bubble |
Thu, Jul 1, 2010 at 8:32:06 AM
Members: | 2056382 | Objects: | 23069 | Forum Posts: | 152325 | Job Listings: | 3 |
