51 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Tips & Tricks >> REVIT & SKETCHUP
Thu, Aug 2, 2007 at 11:28:43 AM | REVIT & SKETCHUP
LUCAS1979
1 Stars: 1 Votes
DOES ANYONE KNOW IF I CAN EXPORT MY REVIT MODEL INTO SKETCHUP?
Thu, Aug 2, 2007 at 12:40:52 PM | REVIT & SKETCHUP
sdbrown
5 Stars: 3 Votes
via dwg exporting.
Mon, Nov 5, 2007 at 9:34:39 PM | REVIT & SKETCHUP
perthmod1
does this work the other way around? Eg. SketchUp to Revit?
Tue, Nov 6, 2007 at 6:27:31 AM | REVIT & SKETCHUP
coreed
coreed Avatar
4 Stars: 16 Votes
you can bring SketchUp models directly into Revit.
There are certain thing that won't import, but the pure SketchUp stuff will import
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, Apr 18, 2008 at 5:58:39 AM | REVIT & SKETCHUP
smokinboulder
so when you move from REVIT to sketchup... you export as a 2007 DWG... then do you have to take it into AutoCAD and export it again or something?  When I try to take the file straight from REVIT to SketchUp all I get is flat linework and no 3D masses... did I miss a step?
Fri, Apr 18, 2008 at 7:39:46 AM | REVIT & SKETCHUP
Did you export to dwg from a 3D view?  It can't be from a plan.
Fri, Apr 18, 2008 at 1:58:24 PM | REVIT & SKETCHUP
jbaysinger
3 Stars: 4 Votes
When in Revit( a 3D view), go to file export cad format.  Then change it to a 2004 cad file and then go into the options. Under solids, make sure it says "Export as ACIS solids"  Click ok and then save.  Now open sketchup and import your cad file and it should work.
JB
Tue, May 13, 2008 at 7:15:56 PM | REVIT & SKETCHUP
lunchtrayrider
3.5 Stars: 7 Votes
You want to export a 3d view and I would recommend using polymeshes instead of acis solids.  sketchup and viz use polymeshes best, autocad does both alright.
Thu, Jun 5, 2008 at 1:41:31 PM | REVIT & SKETCHUP
oshkr
why when i import a skp file to revit and i render tha object comes up in white and not w the texture and color that the object has?
is there a spacial seting i have to do to render skp files?
Sketchup to Revit material problem [ 1 2 ]
Wed, Jun 30, 2010 at 11:58:38 AM
26
Sketchup to Revit
Wed, Aug 26, 2015 at 10:41:28 AM
Furniture Tags & Sketchup Furniture Components
Fri, Dec 4, 2015 at 9:35:34 PM
Sketchup model into Revit
Tue, Jan 8, 2013 at 12:06:21 PM
Warthog
Mon, May 7, 2012 at 11:37:14 AM
Page generation time: 1.7322
