Forums >> Revit Structure >> Technical Support >> curved beam in revit structure 2?
26 Posts No Rating |
How can i make curved beam in RS2? thanks in advance
Create componante in place, then use a sweep with a profile of the beam.
can you explain clearer.
Basic Tab -> Component then up on Properties tool bar click "Create In Place" Then choose what family category you want it in, probably "Structural Framing." Then click "Solid Form" -> Solid Sweep. Draw the curve that you want by either sketching the 2D path or picking a path. Then load the profile of the beam from the library "Load Prifile" and finish the family.
Thanks a lot.but when i try to load from a family(structural ->framing->steel beam),an error sign comes up-> a family is not of the correct category)?
Thanks broncos4life i found my answer completly .
1 Posts No Rating |
I am running into the same problem with Revit architecture 2009. It kept saying "the family is not of the correct category". manifertal, how did you figure it out? thanks,
1 Posts No Rating |
Thanks broncos4life. That was very helpful.
complex curved roof structure |
Thu, Mar 12, 2009 at 1:11:49 PM
curved concrete beam |
Fri, Oct 17, 2008 at 6:10:21 PM
curved beam |
Thu, Jul 20, 2006 at 5:52:48 PM
Curved Glulam Beams |
Thu, Jun 3, 2010 at 3:38:46 AM
vertical curved beam |
Wed, Sep 5, 2012 at 10:55:57 AM
Members: | 2104250 | Objects: | 23178 | Forum Posts: | 152299 | Job Listings: | 3 |
