56 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Stairs & Decks
Wed, Aug 1, 2007 at 10:19:53 AM | Stairs & Decks
Splynter
Hello - I am trying to do a spiral staircase with a "0" center radius - not a curved stair, but a genuine spiral staircase.  Also, I am sure the answer is in REVIT somewhere, but how do you add decks to a residential project? - Splynter
Wed, Aug 1, 2007 at 12:11:39 PM | Decks
Splynter
Hey again,
    According to the "help" section, I make decks under "slabs".  I do not have that option, and I am running 08.
Wed, Aug 1, 2007 at 1:44:36 PM | Stairs & Decks
sdbrown
5 Stars: 3 Votes
A deck would be a floor with a wood material over beams and joists. so you would make a floor that is the thickness of your decking with the appropriate material / surf pattern and cut pattern. Then use the framing tools for the framing.
Wed, Aug 1, 2007 at 1:45:25 PM | Stairs & Decks
sdbrown
5 Stars: 3 Votes
I'm not sure you can make a 0 diam inside. will it have a pole in the middle?
Wed, Aug 1, 2007 at 3:05:54 PM | Stairs & Decks
Splynter
As for the stairs, yes, it would have a pole about 6" in diameter....as for the deck, don't I need walls to confine the sketch of a floor?
Wed, Aug 1, 2007 at 5:00:33 PM | Stairs & Decks
t1slc
I don't believe you need walls in order to make a floor. Just use "lines" to define the perimeter of the deck.
Plan Region & stairs
Thu, Jun 18, 2009 at 1:28:36 PM
Revit 2012 Stairs & Handrails
Mon, Mar 18, 2013 at 7:44:25 AM
decks
Sat, Nov 20, 2010 at 10:26:07 AM
Area Schedules
Mon, Jan 20, 2014 at 7:25:36 PM
Ceiling Access Hatch & Pull Down Stairs
Mon, Aug 27, 2007 at 10:35:11 PM
Page generation time: 1.5035
