43 Users Online (42 Members):
Forums >> General Discussion >> Revit Project Management >> curtain wall door
79 Posts No Rating |
The "curtain wall door - adjustable" seems to be inactive as a download. Does anyone have a similar family, or know how to enable that download? Thanks.
![5 Stars: 3 Votes](/images/stars_5.gif) |
There are many curtain wall doors available from the web library. Click File>open> then in the upper right corner, clikc the link for the web library. look at both the imperial and metric content.
![3.5 Stars: 393 Votes](/images/stars_3.5.gif) |
You may not understand how the curtain wall door works. Unlike other doors that you select the size of, the curtain wall door automatically adjusts to the panel size you put it in. As such, it can be any size ... but you set the size by adjusting the curtain wall.
I am new to Revit, but i do understand how curtain wall doors work. I have a curtain wall installed, however, I need larger framing around the glazing. The libraries that I have do not include a double curtain wall door with some decent sized framing. Thoughts? Suggestions?
----------------------------------- HuntFlo |
When you say framing do you mean the mullions around the door or the stile and rails of the door. Did you look at the web library? I have doors like kawneer style doors if thats what you need. Maybe attach an image of what you need.
Curtain Wall Panel to Curtain Wall Door |
Mon, Jun 23, 2014 at 9:32:11 AM
curtain wall door |
Tue, Jan 31, 2006 at 1:36:58 AM
Curtain wall door frame |
Mon, Mar 2, 2015 at 11:37:33 AM
How to place Curtain/Glass Door for Curtain Wall for Revit Architecture 2012 |
Thu, Jul 7, 2011 at 4:27:10 PM
Retaining Curtain Wall Door Scheduling Data |
Thu, Jan 8, 2015 at 2:47:08 PM
Members: | 2026715 | Objects: | 22994 | Forum Posts: | 152211 | Job Listings: | 3 |
