63 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> How to use yes/no parameters
Fri, Jul 27, 2007 at 11:41:40 AM | How to use yes/no parameters
MYoung
MYoung Avatar
v. 9.0
 How do I use a yes/no parameter.  Its one parameter I haven't figured out yet.  Can I switch on and off objects/lines in a family by creating a yes/no parameter?  If so how do I do that.
 Thanks
Fri, Jul 27, 2007 at 1:33:54 PM | How to use yes/no parameters
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
The answer to your question is "YES". The yes/no parameter is an "ON/OFF" parameter. It can be "Type" or "Instance".
To use this parameter you will need to select the item you want to toggle and click Properties. In the properties you will see a line Labeled "Visibile" (not to be confused with the Visibility Button). Click the tiny button to the far right of the line. This will allow you to add and apply the parameter to the selected item. Once you have applied it you will see your parameter line in the "Family Types" that has a checkmark box. This will toggle the items visibility. By the way, You will not see the effects of this parameter untill you load it into a project.
Fri, Jul 27, 2007 at 4:19:53 PM | How to use yes/no parameters
MYoung
MYoung Avatar
Thanks a lot.
 I figured it was something simple, but I just couldn't nail it down, works great, I appreciate it.
Mike
Wed, Aug 8, 2007 at 12:16:42 PM | How to use yes/no parameters
JHanby
3.5 Stars: 3 Votes
I made a yes/no parameter for text on a titleblock.  Works fine however I want to change the name of the parameter and can't seem to see how to do it.  I tried right clicking on the parameter in the Associate Family Parameter dialog box but nothing happens.  Is it even possible to change the name?
Wed, Aug 8, 2007 at 12:36:11 PM | How to use yes/no parameters
MYoung
MYoung Avatar
You can change the name by going into the 'family types...' dialogue box on the design bar, and clicking 'modify' under the parameters headline on the right side.
Thu, Mar 3, 2011 at 12:16:03 PM | How to use yes/no parameters
2labman
Evidently you can't do this with Images?
Thu, Mar 3, 2011 at 12:30:08 PM | How to use yes/no parameters
MYoung
MYoung Avatar
Control Image visibility?  Not like most objects, as far as I can tell.
However, you can create an opaque filled region to mask out the image, and put a visibility parameter on that.
Mystery parameters - shared?
Tue, Nov 10, 2015 at 7:06:20 AM
Titleblock Parameters [ 1 2 ]
Thu, Mar 13, 2014 at 4:57:53 PM
17
Instance Parameters in titleblock not linking
Wed, Dec 28, 2011 at 10:31:23 AM
12
Shared or Project Parameters?
Tue, Jan 19, 2010 at 7:01:11 PM
Shared Parameters - Schedules multiple parameters one column?
Thu, Oct 4, 2012 at 7:10:20 AM
Page generation time: 0.3826
