71 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> revit 9: light fixtures
Thu, Jul 26, 2007 at 12:24:24 PM | revit 9: light fixtures
Bartelson
Bartelson Avatar
i put what revit im using but i dont know if that is where it goes.
anyway, i want to know how to make light come from a fixture i made in revit. i see all the other light fixtures that i download, and when you render them, it looks like light is actually coming from them. but when i make it, the "bulb", or the object that i use, only sort of glows, and not like the other ones on here. please help
Thu, Jul 26, 2007 at 3:46:40 PM | revit 9: light fixtures
JHanby
3.5 Stars: 3 Votes
Check the lumens in the properites.
TIP:A lumen indicates the amount light emitted from a light source. For incandescent lights, the ratio of lumens to watts is approximately 17 to 1. For fluorescent lights, the ratio is approximately 60 lumens to 1 watt. If you do not specify a value for lumens, Revit Building uses a default value of 1700 lumens, which is approximately equal to a 100-watt incandescent bulb.
Light source inside the light fixture
Fri, Feb 22, 2013 at 7:24:33 AM
turning on light fixtures
Wed, Oct 16, 2013 at 10:53:11 PM
Face Based Light Fixtures
Tue, May 12, 2009 at 5:57:36 PM
Turning Off Light Fixtures In Linked Model For Rendering - How To?
Mon, Jun 20, 2016 at 3:57:37 AM
The lighting fixtures wont show up in my final revit 2013 rendering.
Wed, Jul 31, 2013 at 3:23:19 AM
Page generation time: 1.7207
