51 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Floor Finish
Thu, Jul 26, 2007 at 10:21:57 AM | Floor Finish
sparanomooney
Does anyone know how to give one floor different sections of finishes?  For example, if you have a slab on grade that has three bedrooms on it, how could you give one bedroom carpet, one tile, and the other wood floors?  The only way I can think to do it is to draw different floor sections---is there a way to split the floor?
Thu, Jul 26, 2007 at 10:43:37 AM | Floor Finish
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
One of the most common workarounds for this issue is to create your whole floor as just the slab or other structure. Then add floors on top of the structure floor that are made up of only the finishes (ie carpet, wood, tile ..etc). When doing this you will have to set the offset from base on one or the other of the floor to get it to come out with the slab under the finish.
Thu, Jan 15, 2009 at 2:10:15 PM | Floor Finish
twillson
When doing this, how do you link the floor finishes with the room tags/schedules?
Also, someone mentioned being able to create base elements as sweeps which would also be part of the schedule; how is this done?
Finish Flooring as part of Structural Floor assembly
Fri, Dec 26, 2008 at 8:42:14 PM
Finish Floor
Tue, Jul 21, 2009 at 5:05:38 PM
Adjusting model from finish floor to subfloor
Wed, Feb 26, 2014 at 2:12:05 PM
Subfloor Vs Finish Floor Elevation
Tue, Jul 15, 2014 at 7:58:04 AM
floor finish showing though
Thu, Oct 6, 2011 at 12:29:11 PM
Page generation time: 0.5514
