54 Users Online (53 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Areas on a Title Block
Wed, Jul 25, 2007 at 5:38:38 PM | Areas on a Title Block
grmorris
I've searched high and low, and unforetunately have come up empty.  What I'm trying to do is recreate our very simple title block, so that Squarefootage is automatically updated on the title block.  We've  always done it in CAD by just recalculating it and editing the text.  I'm trying to set it up in revit so that it will automatically update the title block.
I have several area categories.  Generally divided into 2 sections - heated and unheated.  Then those to areas are broken down by floor levels.
 What I've done so far is create my own set of shared parameters that include everything our old CAD block had on it.  I then inserted new titleblock into a new revit residential project, and created corresponding areas for my labels.  I can't seem to figure out how to associate the actual area with the label so that the label displays the square footage from the area corresponding to the label.
 IT's long winded I know, I wanted to give as detailed an explanation as I could, hopefully it makes sense to someone, and thanks to anyone for any information you can provide.
Font on Title sheet absent from project Title Block
Thu, Sep 15, 2022 at 12:31:27 PM
How to import my title block from AutoCAD?
Mon, Sep 10, 2007 at 4:25:44 PM
12
In the default Revit Templates i couldnt find revit title block
Fri, May 23, 2014 at 7:22:24 AM
How to link a Revision Schedule on Title sheet with Title Block
Fri, Jan 11, 2013 at 7:26:27 AM
project title block
Tue, Dec 1, 2009 at 2:18:46 PM
Page generation time: 1.0446
