Forums >> Revit Structure >> Technical Support >> Tags
11 Posts No Rating |
I am trying to create a tag to show the beam reactions, and I am running into some trouble. I have created a generic tag, but it won't seem to actually tag anything. Does anyone know how to make a generic tag tag a beam? I am also trying to get a generic tag that I made tag a detail component, but since it is not a detail item tag, it is not working. Can you load a generic tag as a detail item tag, and if not, how do you make a detail item tag? Thank you in advance!
I created a new Structural Frming Tag, starting with the generic tag template. I made some shared parameters that I loaded into my project and the tag family, so I can put the reactions in the beam properties. I attached the tag family, but I dont know if it will work right for you because of the custom shared parameters.
Thank you for your response. I have made a similar tag using the multi category tag. How did you get the generic tag to know that it was a structural framing tag?
In the tag family, go to Settings|Family Category and Parameters. Then scroll down and select Structural Framing Tags.
Thanks! That is exactly what I was missing.
tags tags tags |
Tue, Mar 20, 2012 at 12:10:24 PM
Tags linked in more than one view |
Fri, Feb 27, 2009 at 6:21:48 AM
ROOM TAGS |
Fri, Jul 29, 2011 at 8:25:59 AM
MISSING elevation tags |
Mon, Sep 17, 2018 at 10:55:18 AM
room tags |
Thu, Aug 13, 2009 at 3:54:35 PM
Members: | 2100164 | Objects: | 23171 | Forum Posts: | 152293 | Job Listings: | 3 |
