81 Users Online (79 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> rotate sweep
Wed, Jul 25, 2007 at 9:59:40 AM | rotate sweep
bobv
HiStill trying to solve family problem. Trying to attack from another direction. I create a sweep, but instead of using a profile I use sketch profile. Problem is now I don't get a parameter for angle and I can't seem to get angle to work.  Any help would be appreciated
bob v
Thu, Jul 26, 2007 at 10:18:12 AM | rotate sweep
lpromana
4 Stars: 2 Votes
Hi Bob,
could you explain further what it is that you are trying to acomplish?????
Thu, Jul 26, 2007 at 11:05:56 AM | rotate sweep
kesflower
3.5 Stars: 11 Votes
Are you trying to create a family with a parametric angle?  If you try to do it with a sweep, you'll have to constrain just about everything except the angle that is parametric, and you'll need to create a new parameter for the angle.  (dimension the angle, then create a new label for it.  Then in the family types, you can set how the angle will change in each preset family type.)
 Is this what you're trying to accomplish?
 Best of Luck,
Ruth
Ruth Rau
Main Street Architecture, P.C.
Rotating Sweep Families
Wed, Apr 4, 2007 at 10:28:49 AM
ROTATE ELEMENT
Mon, May 16, 2011 at 8:15:08 AM
3d sweep
Tue, Apr 3, 2007 at 3:13:42 PM
3d rotate
Fri, Sep 28, 2018 at 7:16:26 AM
Can You Flex a Sweep in Components
Mon, Jun 3, 2013 at 2:09:23 PM
Page generation time: 0.9695
