Forums >> Revit Building >> Technical Support >> Lines too heavy in perspective view
Hi, the profile lines in my perspective view are way to dark. I changed view properties and advanced model graphics to override the profile line to be thin lines, but they are still too thick. When i use the "Thin Lines" button on the tool bar i get a image that i feel looks clean and readable. However, the image will not export with these lines. How do i get the image on my screen, with thin lines, to exprort, and not get the ugly thick profile lines? Thank you.
You can try the Settings-->Line Weights-->Perspective Line Weights tab. You can set the values for the 16 different lineweights to a small number. Not sure if this is what you are looking for but it is worth a try.
Thanks that worked great.
......Awsome......
70 Posts No Rating |
Does anyone know how to make this work in Revit 2013?
I don't understand. The settings are still there for you to change. Did you try it?
I can't find 'Perspective Line Weights '
Ignore me.
Found it! It's under Additional Settings>Line Weight> Perspective Line Weights
Floor lines showing through siding in perspective... |
Tue, Apr 15, 2008 at 5:05:11 PM
12
Line styles won't appear in Perspective view |
Tue, Sep 8, 2009 at 3:47:40 PM
Moving Objects in 3d Perspective View |
Wed, Jul 27, 2016 at 3:52:15 PM
perspective view |
Thu, Feb 7, 2013 at 1:47:35 PM
My bump lines are too thick and heavy. [ 1 2 ] |
Thu, Aug 11, 2016 at 2:45:39 PM
21
Members: | 2098726 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
