117 Users Online (116 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Scaling fill pattern
Mon, Jan 24, 2005 at 3:49:27 PM | Scaling fill pattern
rcole
I'm trying to create a family for granular fill under a concrete slab, and the gravel fill pattern I've used appears too large at the scale of my wall sections. Does anyone know how to scale a fill pattern or otherwise stipulate how it is going to be sized in a given view?
Mon, Jan 24, 2005 at 5:51:07 PM | RE: Scaling fill pattern
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Revit consists of two types of fill patterns, drafting and model. A model fill pattern will scale depending on the view. A drafting fill pattern will always be the same in "print scale" regardless of the view scale. So try changing the pattern to use a model pattern. HTH.
Tue, Jan 25, 2005 at 8:54:49 AM | RE: Scaling fill pattern
rcole
OOOH, I ws optimistic that would work! But when I went to the detail I had created to try to change the hatch to the model type I downloaded, I received an error message that "no drafting type patterns found". In other words, it wouldn't let me fill that region with the model fill pattern. I should have mentioned that this is basically a 2D wall section I'm trying to manipulate. Any other ideas?
Wed, Dec 7, 2005 at 7:58:21 PM | RE: Scaling fill pattern
zaklee
I'm having the same problem. I learned that model fill patterns cannot be assigned to sectioned elements. Only drafting patterns can be. Did you come across a solution for changing the scale of a drafting pattern?
Wed, Dec 7, 2005 at 10:13:48 PM | RE: Scaling fill pattern
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
As mentioned on my blog its easy to change between drafting and model patterns: How do I change a model pattern to a drafting pattern or vice versa? Edit the PAT file using notepad and add or change the following values: ;%TYPE=MODEL for model or ;%TYPE=DRAFTING for drafting. You can also set the units with the following operator: ;%UNITS=MM to set to millimetres� http://revitrants.blogspot.com/ HTH.
Thu, Dec 8, 2005 at 10:17:04 AM | RE: Scaling fill pattern
McGraw
Hi Chris, Concrete fill pattern (drafting) appears to be designed for a 1�=1� scale and does not appear to be rescale able. I wanted the cut pattern in my sections to be correct at 1/2�=1�. I copied the concrete text out of revit.pat and copy/pasted into a new file concrete 2.pat and renamed it concrete 1/2 in text header. Then imported and scaled this pattern as concrete 1/2. Sam Post edited on 2005-12-08 10:35:01
Thu, Dec 8, 2005 at 5:11:19 PM | RE: Scaling fill pattern
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
That's correct. No custom pattern in revit once imported is re-scaleable. To change the scale you need to re-import it.
Thu, Nov 17, 2011 at 3:39:53 PM | Scaling fill pattern
hoinj2
Is it now possible in Version 12 (Architecture and/or Structure) to scale imported custom patterns after import?
Thu, Nov 17, 2011 at 4:01:25 PM | Scaling fill pattern
No - this is on the AUGI wish list.  Did you vote?  Link is on our home page.
color scheme/fill pattern
Mon, Jul 9, 2012 at 4:56:37 AM
Clay Roof Tile -Fill Pattern issue
Sat, Aug 6, 2005 at 5:17:40 PM
Solid Drafting fill pattern
Tue, Jun 23, 2015 at 1:35:02 PM
Fill Pattern
Mon, Jun 5, 2006 at 8:13:22 PM
Fill Pattern not show up when print
Wed, Apr 25, 2012 at 4:08:56 AM
Page generation time: 0.3383
