61 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Curtain Panel Glazing with Frit
Mon, Jul 23, 2007 at 5:04:08 PM | Curtain Panel Glazing with Frit
cluttermonger
I would like to add a frit pattern to a portion of a curtain wall panel.  How should I go about placing the frit such that it will appear in all views and renderings.  Do I need to give it a materiality in order to achieve this?  If so, or not, how then?
If I want a variable (by instance or type) dimension to locate the frit, how should I establish a parameter for this dimension.
 I feel sorta silly asking this question, but the tutorials don't ever explain the why of any steps, so I have difficulty backwards-engineering how these pieces are supposed to work together.
Using Arch-2008
Curtain system > glazing panel matherial
Mon, May 28, 2012 at 1:02:14 PM
Doing a Frit in Revit
Thu, Dec 13, 2012 at 9:55:52 AM
Replace blank curtain wall panel
Mon, Oct 12, 2015 at 12:13:56 PM
Curtain system panel problem
Tue, Jul 10, 2007 at 10:08:07 AM
Daylight Calculations for LEED
Mon, Feb 14, 2011 at 5:56:41 PM
Page generation time: 0.3210
