107 Users Online (106 Members):
Forums >> Revit Building >> Technical Support >> Lights on a Column
56 Posts No Rating |
What is the best way to place a light fixture on column? I have several columns on a building with each one hosting a ight. However, the lights are wall based? What is the way around this? Using 9.1 thanks
Few ways to do it. You can make a wall that mimickes your column then you should be able to host to it. The other way would be to copy the light into a new light family that is not wall based. This will be the same for 9.1 and 2008 fyi. HTH Grant Doherty
Edited on: Mon, Jul 23, 2007 at 3:35:51 PM
Thanks I will try the second option first.
Ceiling Lights don't self-illuminate |
Mon, Oct 17, 2011 at 10:21:44 AM
Lights not acknowledged? |
Thu, Jun 23, 2011 at 7:03:41 AM
Revit always renders all of the lights |
Fri, Aug 8, 2014 at 9:24:36 AM
artificial lights not rendering |
Tue, May 7, 2013 at 6:52:56 AM
exporing revit 09 to 3ds max with lights??? |
Tue, Jun 2, 2009 at 5:53:27 AM
Members: | 2042293 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
