79 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> Stair riser at floor connection
Sun, Jul 22, 2007 at 11:18:12 AM | Stair riser at floor connection
Binnsdrafting
I'm trying to create a stair that is more realistic to our local conditions. Here we only have riser material and a stair nosing at the floor level. Revit will not allow me to do the stairs this way. It forces me to have an entire tread at the floor level which is ok except linework doesn't clean this up in the way I need it to. See enclosed picture. Is there a way to end the stringer at my detail line and cut the tread length to only that distance as well or am I out of luck? Any help is much appreciated.
Mon, Jul 23, 2007 at 10:29:33 AM | Binnsdrafting
rkitect
rkitect Avatar
4 Stars: 29 Votes
Quoting Binnsdrafting from 2007-07-22 11:18:12
Like in the attached image?  Try selecting "End with Riser" in the stair type properties (be sure you make a cuplicate of the type so you don't mess up any of the other stairs you already have made of that type) then just make your landing material come out to the stair.HTH
Tue, Jul 31, 2007 at 11:51:27 AM | Stair riser at floor connection
Binnsdrafting
Thank you for your help. That works partially - now my stringers end prior to the landing. I guess I need to play with it as this seems to be the correct path.
Thanks again!
PRECAST STAIR BEGIN WITH RISER LOOKS INCORRECT ON PLAN
Fri, Sep 2, 2016 at 7:03:03 AM
Precast stair with notch connection
Fri, Aug 26, 2016 at 1:05:15 AM
Cleaning up a Stair Tread & Floor Connection
Thu, Nov 3, 2016 at 8:45:39 AM
Stair riser - custom
Tue, Jan 14, 2020 at 5:55:29 PM
Custom Stair Riser Height
Wed, May 27, 2009 at 10:00:38 AM
Page generation time: 1.4556
