50 Users Online (49 Members):
Forums >> Revit Building >> Technical Support >> columns in walls
4 Posts No Rating |
when adding a concrete column in wall (medium or fine detail), the column takes the hatching of the inside layer -gypsum od brick, and the column border in the wall depth disappears. Typically the column should be hatched with reinforced concrete hatching. When the column is flush with the internal face of the wall the column disappears. Is there a way to detach the column from the wall to make it show with border and identical hatch?
admin
![hjacobs Avatar](user_avatar/2.jpg)
![3.5 Stars: 16 Votes](/images/stars_3.5.gif) |
Are you using the default modeling column? You should use a structural concrete column, it will show up inside your wall. Go to your structural tab and load in a concrete column from your structural library.
I hope that helps.
Hiroshi Jacobs
The Catholic University of America |
4 Posts No Rating |
Thanks. I knew this one should be easy.
intersecting walls and columns |
Tue, May 4, 2010 at 5:08:06 PM
Strucutral Columns VS Walls in Call outs |
Mon, Aug 16, 2010 at 8:17:05 AM
Structural Columns not cutting walls |
Mon, Jan 4, 2016 at 4:13:25 PM
walls and columns |
Mon, Aug 29, 2011 at 5:54:46 PM
columns in walls |
Mon, Sep 11, 2006 at 11:53:37 AM
Members: | 2017300 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
