108 Users Online (107 Members):
Forums >> General Discussion >> Revit Project Management >> QUESTION ABOUT FLOORS!!!
3 Posts No Rating |
HAS ANYONE FIGURED OUT IF IT IS BETTER TO CREATE A FLOOR THROUGHOUT AN ENTIRE PROJECT OR TO DO IT IN DIFFERENT SECTIONS?
![4 Stars: 10 Votes](/images/stars_4.gif) |
You can do one floor system that is just your slab, and then do the finishes ie. carpet, tile, VCT, etc seperatly per rooms. Thats what we manily do and it seems to work best.
![eldados Avatar](user_avatar/6083.jpg)
![4.5 Stars: 8 Votes](/images/stars_4.5.gif) |
not sure i understand the question? what do you mean by "THROUGHOUT AN ENTIRE PROJECT OR TO DO IT IN DIFFERENT SECTIONS?" are you refering to compound floors? if so, I tend not to use this method but rather separate the floors layers to their own floor type, this will give you greater control over the project. does this answer your question?
Massing Question - Extending floors into wall core |
Tue, Mar 4, 2008 at 10:27:59 AM
Question Anout Floors |
Sat, May 15, 2010 at 10:31:36 PM
Duplicating floors and ceilings question |
Fri, Feb 24, 2012 at 12:06:41 PM
Question about walls/floors and back splashes on Revit 2011 |
Mon, Jul 26, 2010 at 8:21:54 AM
Joining the Geometry of two floors |
Wed, May 14, 2008 at 5:46:12 AM
Members: | 2017341 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
