59 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> "line is to short"
Fri, Jul 20, 2007 at 11:07:12 AM | "line is to short"
jr8sr3best
why do I get this "line is to short" when i am trying to copy/monitor walls?
Mon, Jul 23, 2007 at 10:48:51 AM | "line is to short"
rkitect
rkitect Avatar
4 Stars: 29 Votes
Just curious, how far are you trying to copy it
Unfortunately, in Revit, there is a such thing as not mocing/copying something far enough away from the original location.  Try moving/copying it further away than you need and then placing it where you want it.
Mon, Jul 28, 2008 at 1:19:04 AM | "line is to short"
KennyGee
KennyGee Avatar
3.5 Stars: 3 Votes
Im drawing details and Im getting this errorElement is too small on screen
is there a way around this???
Mon, Jul 28, 2008 at 9:21:22 AM | "line is to short"
TABEST
4 Stars: 4 Votes
you can use your arrow keys to "move" the lines/walls, or you can just copy it further away, and then move it to where you want it.  I've found that 1/32" seems to be the magic number, if you try to move it less than that, or have a line smaller than that, the application screems at you.  Anyone gotten smaller?  I'd like to know how!
Wed, Feb 23, 2011 at 4:39:34 AM | "line is to short"
Unleashed2011
Ok this is really annoying. I am doing a region fill showing a thickness of 0,5mm and it says "Line os too short".  Only if I make the thickness 0,8mm then it accepts it.  I have also got this problem with smaller circles / radius.
Any sollutions?
HELP! "Line too short" error message
Tue, Jul 24, 2007 at 11:00:01 AM
Looking for a short video to show executive team the "I" in BIM
Fri, May 2, 2014 at 2:23:58 PM
Ramp Error - Line is too short - RAC 2008
Thu, Jan 24, 2008 at 4:20:24 PM
Going from "Title w line" to "Plan Title"
Thu, Aug 23, 2007 at 11:53:11 AM
changing the "family" and "type" names
Mon, Apr 2, 2007 at 5:33:49 PM
Page generation time: 1.6170
