Forums >> Revit Building >> Technical Support >> Tapered Rafter Help (who's the best)
27 Posts No Rating |
Hi i need some help creating a tapered rafter with parametric properties that allows me to adjust the extrusion void of the existing beam and its overall length.. I have tried on numerous attempts to lock the extrusion in place and set up new reference lines etc, but everyting just got too messy.. I know it takes a while to get used to creating such objects.. But if someone could help me maybe in a step by step process. That would be great.. Attatched is the Rafter with it's void already set...
i had the same issue so attempted the attached family. was a few weeks ago, and it worked ok from memory. i think i put an angle parameter, type, in it. have a look, maybe what i did within it, will help with your family.
Thanks Latemore sorry about the late reply but yes your family really helped me, i tweaked it to suit the parameters needed for my family.... Thanks again...
hi debo glad it was useful. how did you tweak it btw, maybe we can all learn from your efforts?
Tapered Opening |
Fri, Apr 14, 2006 at 9:34:27 AM
Can't make a Two Cut - Square rafter cut on a roof |
Fri, Jan 14, 2011 at 6:20:31 PM
tapered beam |
Wed, Apr 13, 2011 at 4:29:38 PM
Tapered LH Trusses |
Fri, Oct 13, 2006 at 5:05:55 PM
Tapered Beams |
Thu, Nov 4, 2010 at 12:53:50 PM
Members: | 2105893 | Objects: | 23178 | Forum Posts: | 152305 | Job Listings: | 3 |
