171 Users Online (170 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Takeoff OR Schedule for host sweeps not possible ???
Thu, Jul 19, 2007 at 2:30:51 PM | Takeoff OR Schedule for host sweeps not possible ???
wayline
I am trying to sort / calculate volume of total concrete (for a residence here in the virgin islands, where it happens to be quite expensive).  I have no problems scheduling walls, beams, typical foundations, slabs etc.  BUT ??? I can't get concrete host sweeps to schedule.  Neither my conc gutter (wall sweep) nor my slab edge (also host sweep) will schedule.  They both have an assigned material (just for graphics?) and an assembly code.  Is this a known problem or am I doing something wrong?
Thu, Jul 19, 2007 at 2:58:54 PM | Takeoff OR Schedule for host sweeps not possible ???
In the last webcast for REVIT Architecture, they indicated that hosted sweeps could be scheduled including lengths.  We are not yet on REVIT Archicture so I can't verify this..... perhaps someone else can.
Thu, Jul 19, 2007 at 3:16:47 PM | Takeoff OR Schedule for host sweeps not possible ???
wayline
Thanks WWHub - are these Autodesk webcasts?   ?? Can anyone verify about scheduling sweeps ??
Thu, Jul 19, 2007 at 4:02:39 PM | Takeoff OR Schedule for host sweeps not possible ???
It was an AutoDESK webcast - see more here:
http://usa.autodesk.com/adsk/servlet/event/search?siteID=123112&id=8506272
Thu, Jul 19, 2007 at 5:07:35 PM | Takeoff OR Schedule for host sweeps not possible ???
wayline
?? Has anyone else run into this problem ??  Sweeps...schedules...nada.
Tue, Jul 24, 2007 at 2:31:16 PM | Takeoff OR Schedule for host sweeps not possible ???
wayline
Someone must know ??  Mr. Spot, I know you know...  Ayudame por favor.
I never forget a favor.
Wed, Jan 9, 2008 at 4:42:44 PM | Takeoff OR Schedule for host sweeps not possible ???
Jhui
Any luck on this? I can't get sweeps to show up on a wall material takeoff.
Wed, Jan 9, 2008 at 5:05:28 PM | Takeoff OR Schedule for host sweeps not possible ???
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Go to View-->New-->Schedule/Quantities and select Wall Sweeps as the category. This will create a schedule of all wall sweeps in the projects. There is no Wall sweeps category under material takeoff though. You can add the Material and Legth Fields to the Schedule. You can also do the same for Gutters, Slab Edges, and Fascias
Thu, Jan 10, 2008 at 8:46:06 AM | Takeoff OR Schedule for host sweeps not possible ???
Jhui
Wow, didn't even see a wall sweeps schedule. I'll have to look around through that.
 Also, I've assigned a material and all that to a wall base but I can't get the base to show up on the wall material takeoff. Any help with that?
Thu, Jan 10, 2008 at 9:03:50 AM | Takeoff OR Schedule for host sweeps not possible ???
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
If the base is integrated into the wall, then I am not sure you can schedule it. I tried to create material takeoff and couldn't get it to show. I use a hosted sweep for my Base Boards. It is a little tedious to place all of them but I can control and schedule them seperatly.
Fri, Oct 24, 2014 at 1:22:24 PM | Takeoff OR Schedule for host sweeps not possible ???
#11
justinburton69
Just figured this out. If you need a Material Legend to include your sweep material, just make an in place family and assign it your sweep maerial. This way you can add your sweeps to your material legend. I created an admin workset, create a inplace family of a wall, assigned it a material of my sweep--and then BOBS YOUR UNCLE-- THERE IS WAS.
Differences between Schedule and Material Takeoff Schedule?
Thu, Feb 9, 2012 at 7:31:54 AM
Material Takeoff
Mon, Apr 27, 2015 at 7:32:16 AM
Tue, Dec 14, 2010 at 4:42:29 PM
Wall Material Takeoff vs. Wall Quantity Takeoff for material description
Mon, Mar 15, 2010 at 1:57:01 PM
Integral Wall Sweeps
Wed, Mar 12, 2008 at 3:44:56 PM
Page generation time: 0.4582
