66 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> model lines not printing
Thu, Jul 19, 2007 at 7:59:03 AM | model lines not printing
larb
Hello,
I'm using Revit Arch 2008, and in my floor plan I have multiple hidden (model) lines.  They show up on the sheet layout, but when I print to our plotter -- some of them disappear and do not print.  However, when I printed the same sheet layout to a pdf, all of the lines are visible.  Any ideas on what the problem could be?
Thanks
Wed, Nov 19, 2008 at 2:08:40 PM | model lines not printing
rbai930002
Same here. Model lines (both solid and dashed, no matter what the line weights are) on brick walls don't print but the ones on different walls do print. Anyone can help us out? Many thanks.
They print under raster processing setting though.
Edited on: Wed, Nov 19, 2008 at 2:10:59 PM
Fri, Nov 21, 2008 at 3:11:39 PM | model lines not printing
ryantownsend
I have a file that was started in 2008. Used model lines on ceiling and wall plans. They were visible both in the view and when printed.... Now we upgraded to 2009, same file, the model lines are visible in the view but are the only thing that dissapears when sheets are printed.    I have searched printer settings and visibility settings.  PLEASE HELP THEM PRINT.
Sun, Nov 23, 2008 at 11:41:31 AM | model lines not printing
tim123
4 Stars: 19 Votes
Are you using vector or raster processing?  Vector may work better with the thin lines.
Mon, Nov 24, 2008 at 9:46:35 AM | model lines not printing
ryantownsend
The funny thing is I am using Vector printing, and when I print in raster they show up.  Some people consider this a reasonable workaround but it makes the pdf's far too large to send to consultants and the line quality isn't as sharp.
Black lines printing grayscale in PDF
Fri, Oct 10, 2014 at 4:46:47 PM
Lines Greyed-out, but Annotations Not When Printing with CutePDF
Thu, Dec 6, 2012 at 7:52:17 AM
missing lines when printing
Fri, Jul 20, 2012 at 12:18:00 PM
black lines
Tue, Jun 20, 2006 at 12:34:18 PM
Can you convert model lines to detail lines?
Wed, Mar 31, 2010 at 12:45:24 PM
Page generation time: 1.1790
