122 Users Online (121 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> surface patern not aligning
Wed, Jul 18, 2007 at 3:14:40 PM | surface patern not aligning
vblevin
does anyone have any ideas why my surface pattern wont align between the first and second floor walls?
Fri, Jul 20, 2007 at 8:50:25 AM | surface patern not aligning
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
What do you mean by "Align"?
If you are referring to your pattern not lining up with edges, you can use the Align tool and select the edge you want to align to.
Fri, Jul 20, 2007 at 9:33:00 AM | surface patern not aligning
vblevin
i mean my vertical siding doesnt align between the first and second floor walls (it's staggered where the level changes).
Fri, Jul 20, 2007 at 9:38:40 AM | surface patern not aligning
vblevin
hey, thankx for the tool tip. the align tool solved my problem. i'm new to this and still learning. appreciate it.
Aligning surface patterns on Curved walls
Thu, Mar 5, 2020 at 11:50:31 PM
Scaling Patern files
Fri, Apr 20, 2007 at 5:47:27 PM
Colouring of Generic Model Patern Based Wall
Thu, Jan 12, 2017 at 12:24:32 PM
11
Material Mapping on Families
Fri, Nov 3, 2017 at 4:56:16 PM
Flat Concrete Tile Roof
Tue, Oct 29, 2013 at 10:31:52 AM
Page generation time: 0.6767
