50 Users Online (51 Members):
Forums >> Revit Building >> Technical Support >> wall - arch - join / remove seam
16 Posts No Rating |
I'm having a bit of a problem with arches/columns. Can't figure out how to combine them properly. Note: my column is actually a wall. See attached image, should explain in a bit, if not, let me know
is editing disabled? forgot to mention, feel free to point me in the right direction if I'm doing something wrong. thanks
Same materials in the same plane can be joined using the "join geometry" tool. (Overlapping squares next to the offset button.)
Thanks for the info. I did some testing and figured out why it happened. The arch and columns were aligned at an odd angle, something like 68.859. Due to that angle, I think some of the snaps were off a bit when i was modeling the column. I chagned everything to an exact 67º, redrew the colums & arches, now join geometry tool works fine. thanks again
trying to mitre a horizontal wall drawn as an arch with a vertical wall |
Mon, Oct 18, 2010 at 6:44:52 PM
Window at the Seam of a Double Curved Wall |
Mon, Jan 28, 2008 at 11:07:42 AM
Clean wall join |
Sat, Apr 20, 2013 at 3:30:48 AM
11
Wall join options |
Wed, Mar 23, 2011 at 7:46:49 PM
90degree wall join |
Sun, Aug 20, 2006 at 9:08:54 PM
Members: | 2017260 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
