54 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> changing material of component - doesnt affect when rendering
Tue, Jul 17, 2007 at 6:28:57 PM | changing material of component - doesnt affect when rendering
ibmarc
i downloaded some components from this site. one of them appeared white in shading style view. when i rendered it, it had materials that i didnt like. i changed the material defenition under view>visibility\graphics, and now the component appeares to be in the right colors - in shading style view, but when i render it, it shows the old material.
what should i do?
tnx 4 any help!
Wed, Jul 18, 2007 at 7:17:17 AM | changing material of component - doesnt affect when rendering
Look at you material's property table, there is more than one item to be set here.  The first (shading) is the generic color of the material when shown shaded.  Within this selection is a box that either fixes this color to what you select or, when checked, locks the material color to the next setting (AccuRender) that sets the color & texture for renderings.  The color for shading can be different then the rendering or approximately the same depending on this checked box.
Sounds like you want the color you set for shading, unchecked the box but did not change the rendering texture/color.
Wed, Jul 18, 2007 at 9:15:30 AM | i want to get diffrent colors when rendering
ibmarc
i dont care how the component looks when its shaded.
my problem is when i render. how do i change the material defenitions so it affect not only the shaded view (which i dont need) but also when i render...?
i mean, i changed the material definitions as i said above, but it doesnt affect the render!
(sorry if i seem not to understand your explanations, im from israel... we dont have revit forums here in hebrew yet...)
tnx alot!
Wed, Jul 18, 2007 at 11:19:40 AM | changing material of component - doesnt affect when rendering
Did you change the material definitions in the family or in your project?  The project settings over-ride the family settings.
Also, do you have your library pathed correctly so AccuRender can find it?
Wed, Jul 18, 2007 at 12:11:46 PM | changing material of component - doesnt affect when rendering
ibmarc
i changed them b opening the family for editing. i changed the definition under view menu->visibility/graphics.
i loaded the component back to the file im working on, overwriting the existing.
then i changed material definitions under settings menu->materials
currently, in shaded view the component has colors (it used to be white), and when i render it, one of the materials (out of 2) is okay but the other one still has the old color which i wanted to change
i guess i missed one of the materials definition in settings menu. i have a huge list of materials being used there (in the material name list, not the material library), so im having hard time to find the right name.
by the way' what do you think of the image i loaded? its the second model im creating in revit
Wed, Jul 18, 2007 at 12:27:30 PM | changing material of component - doesnt affect when rendering
Looks like your getting the hang of it.
    - It looks like your windows may need some work yet.
    - You may want to put a studio light some where behind the camera
Looks like you may have some families (like the chandelier) in here that would be nice to share with others on this site.  Can you do that?
Wed, Jul 18, 2007 at 12:37:52 PM | changing material of component - doesnt affect when rendering
ibmarc
oh
i downloaded the chandelier from this site...
i would love to share families but i dond really have them
im new in the whole modelling thing...
thanks 4 all the help! Smile
changing material of component - doesnt affect when rendering (revit 9.1)
Wed, Jul 18, 2007 at 9:12:22 AM
Rendering materials within components
Mon, Apr 24, 2006 at 1:49:33 PM
Rendering dwg components in 2009
Sun, Dec 13, 2009 at 7:40:47 AM
Phasing and changing material finishes
Wed, Apr 30, 2008 at 11:03:56 AM
Families don't take materials while rendering
Sat, Nov 28, 2009 at 3:22:06 PM
Page generation time: 3.9330
