87 Users Online (85 Members):
Forums >> Revit Structure >> Technical Support >> Subcategory Layers, Colors, and Linetypes translation
![2.5 Stars: 2 Votes](/images/stars_2.5.gif) |
Subcategory translation to AutoCAD drawing file is not assigning the correct layer and line color when translated out using an rte (template) we created. Examples of the subcategories under S-Wall we created are: S-Wall-Conc, S-Wall-CMU, S-Wall-Steel, S-Wall-Wood; with varying colors representing NCS layers, line-weights, and linetypes in plan and projection views respectively. Going through the Revit help, custom layer mapping modifications are translating out to their major S-Wall setting without translating out to the defined subcategories. The new template is in view during translation as the selected translate to file template. What would a correct or better measure to use? This is why we should have a translate to NCS standards selection.
How to export CAD with custom subcategory layer |
Tue, Feb 15, 2011 at 10:08:37 AM
Colors and Printing |
Thu, Jul 19, 2012 at 10:11:31 AM
imported dwg lineweights, linetypes |
Fri, Aug 10, 2007 at 9:22:53 AM
Change linetypes of a wall |
Thu, Jul 1, 2010 at 4:12:41 AM
Help for my curtain wall |
Tue, Jan 7, 2020 at 8:21:54 AM
Members: | 2022486 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
