43 Users Online (42 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> CMU Hatching/ Alternate Bands
Tue, Jul 17, 2007 at 12:54:34 PM | CMU Hatching/ Alternate Bands
Solopk
My intent is to show alternating cmu banding in a typical running bond.  The bands would be a split face and a smooth face every other course.  I have found on this forum a great split face hatch pattern but it is for the entire field.  I do not quite fully understand yet how to properly edit the .pat files.  Is there a way to have a cmu pattern with every other horizontal course indiacting a split face pattern by having a sand texture applied to it?  I have attached the link to the pattern I found on here.  Thanks in advance.
http://www.revitcity.com/forums.php?action=viewthread&thread_id=7541
Fri, Jul 20, 2007 at 9:32:01 AM | CMU Hatching/ Alternate Bands
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
A hatch pattern is basically an array of lines in two directions. To create a pattern that skips a course with sand texture, would be extremely difficult.
The best solution for the wall you want is to
1.Use split face and paint tools to apply the pattern to the wall face or,
2.Edit the wall family to have split regions and apply the material to the necessary regions.
I will try to explan both of these methods as best as I can. In both of these methods you will need to create a custom material with the split face as a surface pattern. There is a default split face cmu that you can modify.
1. Split face is a tool that will divide the face of a wall, floor, ceiling, roof ..etc. You can then use the Paintbrush tool to apply your materials to the resulting faces. This method is time consuming and not recommended if you have a lot of these walls.
2. In the wall family go to Edit/New-->Edit structure. Make sure the Preview Pane is Visibile. Go to the Section Preview and you should see the tool buttons become available. You need to make a new layer/region with the new material applied to it but no thickness.
Click split region and select the heights you want to divide. You can do as many splits as necessary. Next click Assign layers and assign the new layer you created to the areas you want.
If you have any questions on this please feel free to ask.
Fri, Aug 10, 2007 at 8:02:00 AM | CMU Hatching/ Alternate Bands
hugh
3.5 Stars: 4 Votes
This is the CMU pattern with some dots added along one course, arranged so they repeat on alternate courses.
 Hope it's not too late to be of use.
 Hugh Adamson
Cadro Pty Ltd
www.cadro.com/hatchkit/
Fri, Aug 10, 2007 at 8:09:22 AM | CMU Hatching/ Alternate Bands
hugh
3.5 Stars: 4 Votes
Sorry, that link should have been been
www.cadro.com.au/hatchkit/
Hugh
Hugh Adamson
www.hatchkit.com.au
CMU in a cut section
Mon, May 25, 2009 at 12:50:44 PM
stucco bands
Wed, May 21, 2008 at 3:39:27 PM
alternate dimensions
Mon, May 24, 2010 at 1:30:15 PM
Brick veneer stepping at alternate elevations
Wed, Aug 14, 2013 at 8:28:36 PM
Topography and hatching in section / elevation
Sat, Sep 27, 2008 at 7:55:41 PM
Page generation time: 2.7358
