109 Users Online (108 Members):
Forums >> Revit Building >> Technical Support >> Unable to duplicate a view
4 Posts No Rating |
I have a 2 story building using revit architecture 2008. I can duplicate all other views with no problems. But, when I try to duplicate level 1 an error message appears and says, "Work Planes cannot be copied" It only allows me to cancel. I am not sure what I should do. I would like to duplicate the view to have mulitple plans showing, deminsion and room names. I have tryed duplicate and duplicate with details, both show the same error message. Any help is appreciated.
Edited on: Mon, Jul 16, 2007 at 7:07:56 PM
4 Posts No Rating |
I have solved my own problem. After thinking way too hard about it I discovered that I had turned of the visibility of the work plane in Level 1 view. To fix the problem I pressed the reveal hidden elements button at the bottom. I then highlighted everything then using the filter selected just the work plane grid. I then right clicked and unhide element. This allowed me to duplicate the view.
![3.5 Stars: 11 Votes](/images/stars_3.5.gif) |
I have a similar problem now in RAC 2011, the only difference is that i m not getting an error message, i just try to duplicate or convert view to indepentant,,, revit thinks for a few seconds, , and nothing happens. I dont realy understand how you solved your problem there, any advise for this in rac 2011 ?
Edited on: Thu, Dec 9, 2010 at 8:16:39 AM
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
4 Posts No Rating |
same problem with me here. I need to duplicate a similar plan view target on a floor plan. help please!
Unable to Duplicate Schedule |
Wed, Sep 12, 2012 at 3:43:41 PM
Duplicate view |
Wed, Jul 15, 2015 at 1:50:18 PM
Duplicate elevation view |
Wed, Jan 11, 2006 at 4:41:27 AM
Creating duplicate views of elements |
Tue, Apr 24, 2012 at 5:57:37 AM
Duplicate views create duplicate callout tags in referring views... |
Fri, Mar 9, 2012 at 1:37:25 PM
Members: | 2017040 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
