55 Users Online (53 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> importing Autocad files - modelspace & paperspace!
Mon, Jul 16, 2007 at 4:47:42 PM | importing Autocad files - modelspace & paperspace!
twannen
twannen Avatar
I have a co-worker working in Autocad, with an x-ref floor plan in modelspace, and different viewports of that floor plan in paperspace, which I want to bring into Revit.
Is there a way to import that Autocad file into Revit and have it retain the modelspace / paperspace relationship of viewports?  It seems if I try importing the file into a Revit sheet, only paperspace information comes in (without the viewports).  If I import the file into a Revit drafting view, only model space information comes in.  This may be an Autocad question, but aside from re-creating all of the veiwports in Revit, is there a way to "flatten" the autocad image into either 'space and have both sets of info?
Thanks!
Mon, Jul 16, 2007 at 6:35:50 PM | importing Autocad files - modelspace & paperspace!
TomDorner
4.5 Stars: 25 Votes
Take a look at this BLOG
http://autodesk.blogs.com/between_the_lines/2007/04/autocad_export_.html
or do a Google search on 'export layout'
The tool is still in alpha and only works with AutoCAD 2008, but it does what you are looking for.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Tue, Jul 17, 2007 at 8:25:50 AM | importing Autocad files - modelspace & paperspace!
twannen
twannen Avatar
Thanks Tom.  This looks like a cool product.  We will try it out and see how well it works.
Model/Viewport placement Modelspace/Paperspace when exported to AutoCad
Thu, Nov 12, 2009 at 10:01:10 AM
inport dwg with paperspace views
Fri, Apr 9, 2010 at 8:34:14 AM
REVIT'S POOR GRAPHIC DESPLAY WHEN IMPORTING AUTOCAD FILES
Sun, Sep 24, 2006 at 10:37:22 PM
Importing from & exporting to AutoCAD
Wed, Nov 2, 2005 at 10:10:25 AM
Having trouble import Autocad files into Revit 2010
Tue, Jun 9, 2009 at 8:55:03 AM
Page generation time: 2.1206
