121 Users Online (120 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Render engines
Thu, Jan 20, 2005 at 7:52:03 PM | Render engines
Moose
1 Stars: 4 Votes
Just wondering if there are any additional render engines/add-ons that are available for Revit? I have used other programs that allow you to choose to render your model as a water colour, pencil sketch, etc. Just thought there might be something out there that will do it for Revit. Thanks
Thu, Jan 20, 2005 at 7:57:48 PM | RE: Render engines
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
There are no addon's or plugins for revit... There is however a revit plugin for Viz 2005 that allows you to import a revit 3d Dwg file export and retain all your material settings...
Thu, Jan 20, 2005 at 8:02:24 PM | RE: Render engines
Moose
1 Stars: 4 Votes
Thanks for that. Just another quick one. I hope I'm not speaking out of school here, but the program I had used was ArchiCAD. Do you know if we can open a Revit file in ArchiCAD??
Thu, Jan 20, 2005 at 9:02:09 PM | RE: Render engines
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I've used archiCAD before as well, and no you can't. No other program is capable of importing a revit model as an rvt file, only as dwg.
Thu, Jan 20, 2005 at 9:19:53 PM | RE: Render engines
Moose
1 Stars: 4 Votes
Thanks for that
Thu, Jan 20, 2005 at 9:38:00 PM | RE: Render engines
riksta
Where can you get this plugin, and can you retain materials from revit into 3ds Max??
Thu, Jan 20, 2005 at 9:40:42 PM | RE: Render engines
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Haven't tried it with max but it should work. The file is on the Revit 7.0 cd and is also for download at the autodesk website http://south-apac.autodesk.com/adsk/servlet/index?siteID=1157326&id=3360945
Rendering - What do you use?
Tue, Feb 20, 2007 at 9:04:30 AM
Render goes ok but when i change angle - the render is black
Tue, Oct 20, 2015 at 4:38:11 AM
Revit render or 3ds max design render?
Sun, Jan 4, 2015 at 10:19:29 AM
RENDER NOT HAPPENING...
Tue, Sep 20, 2005 at 5:00:45 AM
render masterplan
Sun, Jul 31, 2011 at 1:14:53 AM
Page generation time: 0.6195
