40 Users Online (39 Members):
Forums >> Revit Building >> Technical Support >> adding a parameter in an inclined wall family
2 Posts No Rating |
Hi, guys! OK, so I made a family of an inclined wall and I want to make the angle of incline an editable parameter. How do I do this? I attached a picture of what I already did. Thanks!
83 Posts No Rating |
did you ever find a solution to your inclined wall question?
THe process is the same as adding a parameter in a family. Draw a reference plane at the desired angle. Add a dimension and instance parameter for the angle. Then constrain the wall extruded sketch to it. Alternatively though I would do this with a mass so I can apply a standard wall to it using pick face...
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer  B. Arch)
Hi, check this example....
Edited on: Mon, Dec 29, 2008 at 5:32:35 PM
Windows/opening/curtain system on inclined wall |
Tue, Apr 21, 2009 at 5:16:45 AM
editing an inclined wall |
Tue, Apr 26, 2011 at 4:05:45 AM
Inclined curtain wall |
Wed, Jul 30, 2014 at 11:43:13 AM
ADDING WALL HEIGHT PARAMETER TO WALL SCHEDULES |
Mon, Aug 30, 2010 at 12:57:36 PM
concrete beam on top of inclined wall |
Wed, Jun 20, 2007 at 11:09:17 AM
Members: | 2017222 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
