108 Users Online (107 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Project Square Footage?
Wed, Jul 11, 2007 at 3:50:44 PM | Project Square Footage?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
Is there an easy way in Revit Architecture 08 to view the projects overall Square Footage?  If so, how?  I need to know the overall square footage with walls, etc.  Thanks!  I'm sure its simple and I'm just blind... haha Smile
 LHAA
 Licata Hansen Associates Architecture
Reno, NV USA
Wed, Jul 11, 2007 at 4:13:58 PM | Project Square Footage?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
I need to know ASAP! Please.
 LHAA
Reno, NV USA
Wed, Jul 11, 2007 at 5:48:10 PM | Project Square Footage?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You have a few options:
Using your room schedule and areas of the room then calculate total.  You'd also need to set your room bounding properties to have the wall centreline be the bounding element.  This relys on you having every room tagged.
Using an Gross Floor Area plan, simply draw area boundary lines around your building for each level and then create an area schedule to calculate the totals.
For a quick take off simply create a filled region (Revit 200Shadey around your building.  Finish sketch and look at your properties you'll see you have an area for the filled region.
OR if you have one floor per level with no overlapping segments you could create a floor schedule with areas and calculate totals.
HTH.
Regards,
Chris.
Thu, Jul 12, 2007 at 12:17:57 PM | Project Square Footage?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
Awesome!  Thanks Mr Spot!
 LHAA
Reno, NV USA
Wed, Feb 20, 2008 at 2:13:14 PM | Project Square Footage?
Pmerk
How do you set the room bounding properties to have the wall center line be the bounding element? Thanks!
Looking for quick easy square footage calculator
Mon, May 19, 2014 at 10:49:35 AM
square footage
Wed, Dec 14, 2005 at 11:18:17 AM
Question about square footage and Rooms
Wed, Jan 30, 2013 at 3:35:39 PM
Square Footage Tool??
Thu, Sep 14, 2006 at 9:27:45 AM
Square Footage Issues
Tue, Mar 1, 2016 at 4:26:14 PM
Page generation time: 1.1984
