115 Users Online (111 Members):
Forums >> Revit Building >> Technical Support >> Defining Floors
7 Posts No Rating |
Okay I'm using Revit 2008. With walls there is a way to define how they are placed based on Core face, centerline, etc. I am modifying a floor and I want to use the structure of that as the level rather than the top of the whole assembly that I am creating. Is there a wat to do this?
1 Posts No Rating |
I've encountered the same issue - when trying to refine the floor structure placment the core boundary doesn't relate it to the level - the floor is always created below the level it was created on. Aside from using the 'offset' instance parameter (which I am wary of using because I want to maintain the ability to change the floor type without backchecking the offset), has anyone else encountered this problem and/or discovered a good work-around? Thanks.
Floors - Constant-height-defining lines must be parallel?? |
Tue, Aug 29, 2006 at 12:38:25 AM
defining a space with multiple offset floors (MEP2011) |
Tue, Jun 29, 2010 at 12:30:50 PM
Huge Regeneration time after defining a new element |
Wed, Feb 17, 2010 at 8:34:59 AM
Joining the Geometry of two floors |
Wed, May 14, 2008 at 5:46:12 AM
Grouping Floors |
Mon, Aug 22, 2005 at 3:47:49 PM
Members: | 2022461 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
