65 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> 2008 Backup Directory
Wed, Jul 11, 2007 at 4:11:59 AM | 2008 Backup Directory
Safety
1 Stars: 1 Votes
Does anyone know if it is possible to change the directory for your backup files that are being created automatically?
My larger projects that have several links create backups in the same place on my drive and I would like to place them in a seperate folder in order to remove the clutter!
Cant seem to find anything on changing the directory maby someone can help?
Wed, Jul 11, 2007 at 9:49:17 AM | 2008 Backup Directory
Elmo
3.5 Stars: 4 Votes
This is not possible at this time. What you can do though is specify how many backup files you want per a project though. If you go File>Save As there is a command called options near the bottom right. Here you can specify how many backups you want for that particular file. It always recommended that you keep at least 3 back up files though since you never know when something could go wrong.
Wed, Jul 11, 2007 at 9:56:36 AM | 2008 Backup Directory
Safety
1 Stars: 1 Votes
Thanks knew that one already!
So thats that, have to add that to the wishlist!
Backup File Directory
Wed, Apr 10, 2013 at 1:44:43 PM
Backup
Wed, Jul 30, 2008 at 6:35:09 AM
Archive log files?
Wed, Apr 12, 2006 at 9:38:39 AM
Recovering a file from Backup Files W/O/ the original File
Fri, Feb 6, 2015 at 9:40:44 AM
save 2 backup files
Tue, Dec 4, 2012 at 6:51:29 AM
Page generation time: 0.9065
